- Fri Aug 10, 2018 1:17 pm
#8723
Morning All.just stripped primary inner and outer to renew oil seals and my query is regarding the crankshaft breather bolt which is fitted with a brass bush with a metal disc.I have dismantled this assembly and cleaned and re assembled it but I can blow through the bolt, but I can also suck, surely the logic behind the metal disc is to provide a one way flow, which it isn't. Should I replace the assembly? Thanks all. (Mark!!)
metal disc
metal disc
