- Tue Jul 10, 2018 7:53 am
#78420
Hi Tom, its unusual for it to be as simple as a disconnected connection but its always worth a quick check before going back to the dealer. In my experience, the easiest connection to become unsecured is the TPS sensor, this is located on the throttle body on the horizontal plane (battery side). The battery is very close to this sensor, and occasionally when the battery's get fitted the sensor can be unsecured from its connector and then begin to work loose when in use. If this is the case it will be obvious, but you will just need to pull the battery forward slightly to gain access and check the connection.
The other places to check for a Euro 4 (2017+) model would be:
- Oxygen sensor (just on the front of the exhaust pipe and follow the wire up to the block connector)
- Crank position sensor (follow the wires from the top of the right hand cover, the block connector to check is usually between the battery and left hand tool box, there will be a big red block connector for the alternator and a smaller 2 pin connector for the crank position sensor, this 2 pin connector is the one to check. Unlikely to be this sensor as the bike will not run if disconnected)
- Air temperature sensor (back side of the airbox)
- Coil connections (from coil located above the cylinder head. Again, unlikely to be this sensor as the bike will not run if disconnected)
- All sensors on the throttle body (TPS, MAP and Injector)
- Air injection system can also flag a fault code (located above the cylinder head)
If you do find loose connection and plug it back together, the engine check light may take a few cold starts for the light to turn off even when the engine is performing as it should. If you wanted to go a step further, you can make the bike perform a "self diagnosis" which would help to narrow down which sensor it thinks is causing the problem.
Hope this helps!
