I don't think there is a breather on the primary chaincase on recent bullets. Not so I've noticed anyway. Again, the question would be how it got pressurised in the first place because there's nothing in there that produces gas... which brings us back to the crank seal.
By enman
#78377
Hi crank seal definitely fitted correct way around, I did rebuild 18 months ago and problem only just surfaced, since I drained and refilled both engine and Chaincase I've done 180 miles with 20/50 in each and Chaincase level is constant as is oil level with no leaks,so I must assume it doesn't now like ATF in Chaincase although I've been using ATF in it for 8 years
By Leon Novello
#78393
Vince: Automatic Transmission Fluid (ATF) is very thin, usually around 5W/10, engine oil is a lot thicker,20-30-40- 50 etc. It will dilute the engine oil.
