By Beezabryan
#78029
Do not see why not.
Have a look at Mr H's catalogue & the parts lists where you should find all the necessary bits & pieces.
Make a list, price it, add VAT and carriage, tot it up and then pick yourself up off the deck.
Might save a few bob if you can get good second-hand parts, check out our hosts' used parts section, or sell your K/S Bullet and just buy the 4 speed electric start version, which might actually be easier. There's one on ebay for £1,710 at the moment, plus a Sixty-5, some Electra-X models and loads of EFI Bullets.
By Presto
#78040
To try to answer the question [;-)]. No. Not a practical modification to convert to electric start. The parts required to be changed are extensive - including the crankshaft, crankcases and goodness what else.
By papasmurf
#78042
po pott, you could explore going down the belt primary drive route with a starter ring on the clutch cage. (There are several kits on the market for old Brit bikes and old kick start Hardly Dangerous's.)
