- Fri Jul 06, 2018 8:09 pm
#8625
My father and I purchased a 2002 Bullet 500 a couple months ago. It was not running at the time, and had been in storage for a couple years. The engine was hopped up to a 612cc by the original owner, but he had a significant failure. The gentleman we purchased the bike from purportedly had the engine rebuilt to a more standard displacement and configuration by Perry's Sidecars in Texas a year or two before it went in storage.
After cleaning the carb and re-timing I managed to get it running, only to discover it had no oil pressure. Further inspection revealed a failed oil pump spindle. I have since replaced the pump spindle, worm gear, failed distributor base gasket, oil and filter, and installed the filter packing piece and magnet from our hosts. After more tinkering with the Amal 932 I was able to get the bike idling well enough, and it ran sufficiently well to ride it around the block a few times. After it warmed up a bit the engine began making what I would describe as a hollow, metallic clanking sound when revved. No untoward noise at idle, only at higher RPM. I corrected a loose rear fuel tank fixing bolt, ensured the exhaust was secure, generally looked things over to make sure there wasn’t some external source for the noise, and I can’t find one. It sounded to me like it was cylinder/top end related, and to my ear sounds similar to examples of piston slap that I’ve heard on YouTube.
I pulled the head, cylinder, and piston. The engine has eaten some metal per that pump spindle gear failure. I’ve not disassembled and closely inspected the head and rocker arms yet, except for noting that the top half of the exhaust rocker arm bearing set looked like it’s picked up some metal on the race. The cylinder measures pretty close to 3.305†everywhere—front to rear, side to side, top-middle-bottom. The bottom of the piston skirt, 90 deg to the piston pin, measures at 3.302. This would seem to make piston slap an unlikely source of the noise, as my understanding of slap is that it would be the result of loose tolerances.
Here’s a shared gallery including some shots of the cylinder and piston. The cylinder has vertical streaking from metallic debris, though only one or two spots barely catch a fingernail—I would think overall it should just hone out. The piston picked up more damage, and I’d like to seek opinions on that—do you think that could be cleaned up and returned to service, or would be it be prudent to replace it?
https://photos.app.goo.gl/EKW1x8NBAuQe34Xe8
I’m at a loss as to the source of the noise at this point, though I still have to disassemble the cylinder head and check the valves. I wiggled the small end of the connecting rod while referencing a rule, it appears to have about 1/16†play—Snidal’s manual says 3/16†is the limit. It doesn’t seem to have any noticeable “in and out†play. I’m hoping we’re not looking at having to split the case halves, and it ends up being a top end issue….suggestions appreciated. Thanks,
-Ryan
-Ryan
