By 25Tom
#8613
Hi, I've just received a stem nut clock from our hosts. It looks perfect and fits the stem nut very nicely. It's set to the correct time at GMT, but we're now on GMT+1 so I want to change the time. The instructions say "the time setting crown is located behind the bezel at the position of 3'clock" but I can't see anyway of getting 'behind the bezel'. Has anyone managed to get to the clock crown to set the time? If so, what's the trick? On a similar note, the instructions for changing the battery say 'insert a screw driver into the case notch at the side of the back cover' to access the battery, but I can't see any such notch and can't take the back cover off. Still, that's a problem for another day.
#77753
Hi Tom you need to use a thin blade to slide under the tapered bezel to lift the face of the stem, this can be done with the stem in place on the bike, then you can see the button? to alter the time. If I remember right you need the thin blade to get the bottom off to change the battery. Hope this helps.
