- Thu Jun 21, 2018 10:46 am
#77578
Judging by your comments you should probably fit a better pair of silencers anyway, as they will make the bike more pleasant for you to ride as well as being a bit more neighbour-friendly, if that's an issue. You can then check the effect on your carburation. As a rule more open exhausts need richer jetting, while at the other extreme something like the Electra-X in factory trim was jetted very lean for its intentionally restrictive lean-burn exhaust.
