- Wed Jun 20, 2018 3:16 pm
#8586
The Bullet has run well and is now my regular ride but recently it has become a little harder to start. This seems to have coincided with some night riding. I checked the battery today and it's down to 11.5v with no load and drops to about 9v when the ignition is on. It will just about start at that level and the meter then shows a charge rate of 12.54v. This seems low but then its only being fed by 4 coils. Agonising over whether i have a failing battery, a failing regulator or 'they all do that sir'.
Had a look at out hosts website and they only seem to offer a Boyer Powerbox as a replacement and I am reluctant to spend £67 + Vat & postage without being sure which part is faulty. It's not desperate as clearly once running there is enough juice to keep the sparks flying and the headlight is fed direct AC anyway. For now I will pop it on the charger overnight just to be sure of a good start in the morning.
Would welcome any thoughts on how to isolate the problem.
PeterF
PeterF
