- Sat Jun 02, 2018 11:11 am
#8540
I have acquired a 700 Meteor which had been restored but left idle for many years. After the usual cleaning up it started, but it runs very erratically. I have thoroughly cleaned the carby which is an Amal concentric 626. The main jet is a 190 and the needle jet is 106 and I have replaced both needle and jet with a good spare. I have tried all 3 slots on the needle which makes no difference. The mixture screw doesn't improve things either. The points and leads are new. The plugs are new. The distributor cap is new and the timing is spot on at a little after TDC. (Strange but that's what the book says).I have moved the timing back and forth by turning the distributor to no effect except slowing the motor. I suspect this is not the correct carby for this model so is there anyone out there with a similar Meteor Twin who can tell me how their bike is carburetted.The compression when tested with a gauge seemed to be around 35 pounds each side. Pouring oil in the plugholes does not change this. The plugs are quite black and the intake manifold does not appear to be leaking air. What could cause it to run so rough when it starts so easily. The mufflers are free flowing and quite loud and the air filter is just a POD type.Any ideas?
