- Tue May 01, 2018 9:59 am
#76544
Two ways of telling an ABS model, if you look thru the engine behind the starter motor, if its abs you will see black abs unit, if no abs you will see strait thru no black unit. also on the front and rear wheels there will be abs rotas on the discs, non abs will only have disc. And I agree about buying a low mileage used, There are some cracking deals on E BAY with low mileage, A bike that's done a 1,000 mls has had its first service and is nearly run in.
