- Thu May 03, 2018 9:45 am
#8400
Hi I have had a go at adjusting my tappets as per this video here:
https://youtu.be/4bmgJPyCUNU
I set tdc using the ampmeter and removed the cover and I have found a bit of a problem, my rear one intake, would not turn freely and was very tight so I loosened the locknut and and adjusted it so it would spin freely with no up and down play as best I could. The front exhaust one is a diffent story, it is tight but not as tight as the rear one was before I adjusted it, I can turn it with my fingers but not freely if you know what I mean it needs loosening. The problem is I cannot shift the locknut to undo it and I dont want to use force. The problem is compounded by only having metric spanners which are either too loose or too tight so I need to get a set of imperial ones as well. Any ideas on how to go about freeing up the lock nut without damage? I will get some other spanners and have another go the bike seemed to run better well sound better now I have loosened the intake tappet so that is one good thing.
