- Sun Mar 18, 2018 7:52 pm
#8196
(New readers might start with a search here for 'Ebay Bullet' messages, if you like a tale of misguided bike buying!) Just to clue you in, this is a 1955 350 Bullet bought cheap and incomplete off Ebay.
Well, I finally got around to stripping the engine to find out why the crank wouldn't rotate more than about 270 degrees after the engine rebuild. I know it's been ages but the long held up "cosmetic" rebuild of the Works Replica and sorting some jobs on the S2 Interceptor got in the way. As it's been snowing and generally crap outside recently the workshop is quite a warm place to be since I put in a plastic strip warehouse curtain to divide it in half, another job that held me up! So, taking everything down to the cases, magically the crank turned freely, really odd. I decided to put it back together as it was but using a different oilpump worm on the timing crank end and a different nut and washer on the drive end and blow me, it all turns over nicely. The reason I used a different worm was I couldn't find the one I took off and the sprocket nut was really tight on it's threads so I found one that fitted better and a washer that looked thicker and more like a proper Enfield one than the one that had been fitted. I put the cases back in the frame (using the technique of removing/refitting the gearbox studs,) fitted the primary and clutch, all ok, then piston barrel and head. Crank still turns over freely. I have moved on to fit the head steady, exhaust and various other parts, using studs, nuts and bits and bobs from the various boxes of old Enfield bits I have accumulated over several projects. Today it finally feels like progress!
