- Fri Mar 30, 2018 10:03 am
#75186
I know someone on here had an unexpected webbing in the casting that fouled the flywheel and had to burr it down before fitment. I'm nearly at the stage you're at and I went over the casings with a pneumatic whizzer to remove any casting marks from the inside because the new flywheels are a much closer fit.
If it's still sticking, might be worth putting some engineers blue on the flywheels to check for rubbing spots?
