By Reds
#8090
Hi,
In the process of losing the garage into a conversion and will have to store my 1999 bullet deluxe under a bike cover under the car port any advice against bad weather re rust etc as always kept bikes in garage .
Anyone else keep their enfields outside ?
#74663
If you're not using it (even if you are,) spray the hell out of it with ACF 50. That G is too nice to go rusty!
By Presto
#74664
Go careful! ACF50 is so efficient and tenacious that light spraying from time to time is all that is needed. Don’t overdo it – it'll be waste. And it's expensive. But very good!
By Craig
#74666
All my Enfields have lived down the side of my House under a lose flapping Bike cover..(Plenty of Air around them) water do's not harm them no major rust...Salt though is a danger..used plenty of WD & 3in 1 wiped over them over the years and No Major probs..Tried ACF50 good stuff I know..But I could not spot the difference.. Condensation & road salt ARE a danger..(If you are under a car port down the side of a House you should be fine.)IMHO
