- Mon Mar 05, 2018 7:05 am
#8141
Hi,
Got myself a 1979 350cc BUllet which was build in India (and looks like a cast iron).
The bike was sitting for a while but was kick starting with no problem. After a 20 minutes ride, the bike stopped and didn't start again. I took the carb apart and it was really dirty. Assembled all and the bike still doesn't start. Changed the plug, but that didn't help.
It seems the kickstarter runs freely with no resistance/compression. I thought the decompression lever/cable sticks and tried to free it with WD40, i looks like it helped a bit but it still feels like there is no compression.
The bike did start a couple of times when i opened the throttle all the way, but i was able to keep it running only with the throttle open, and it didn't idle at all and died after a few seconds.
The mixture screw is opened 1.5 times (3 halves), and petrol is flowing to the cylinder since i know i flood the cylinder after trying to kick start it several times and it smells of petrol all around.
Any ideas on what to do next? i though about checking if the valves clearance is ok (But don't understand why they would go out of alignment).
Thanks in advance!
Daniel
Thanks in advance!
Daniel
