- Mon Jun 19, 2017 7:21 am
#7422
I bought a small 4 cell lifepo4 battery so I can get rid of the battery carrier. I'm also thinking of getting a motogadget m-unit v.2 to clean up the wiring, and allow me to make do with less switch work on the handlebars.
Looking at the wiring, to me it seems that the casquette would make a good place to give these their home. It's out of sight, big enough, and it would reduce the wiring a lot. All that'd be left below the seat would be the reg/rect (which I'm replacing with a boyer powerbox) and the startmotor solenoid (which I'm only leaving in so I can temporarily hookup a larger battery to save my leg when I need to work on the bike.)
Is there any reason this would be a bad idea? Heat or vibrations maybe?
