- Wed Jan 17, 2018 5:35 pm
#73577
Thanks all so far.
I'm asking because I rather fancy one and have found two rather nice examples and during my limited reseacrh so far warping, or was it craked crank cases (???), blown head gaskets, elongating of the engine mount brackets during use, tank issues, such as leaking seams from high speed use, and several other things, were listed in the book I'm reading at present (can't check because the book is at work).
I've found a 1960 model and one allegedly from 1963.
I appreciate that it being a classic it will equire some fettling and fiddling, and I admit that when I first started looking at them, the idea of making mice meat of the Bonnies at my local T.O.M.C.C branch was rather appealing (wink).
I've read that many of the engine issues were sorted by a reduction in compression ratio which dropped the BHP to 40 from around 52 (sad).
I am no stranger to classic vehicles, after having two Morris Minors and a Series IIa Land Rover, but the only classic bike I've had was a somewhat different Yamaha YR5 350. Just gathering as much research as posible before I make up my mind. It would be rather nice to have a triple of machines in the stable: a single, a twin and a triple. It's the twin I'm after (possibley). Cheers all, Chris.
