- Tue Jan 02, 2018 9:05 pm
#73304
Papasmurf, why not leave the solenoid as is, make up a short cable (approx. 2" long), on one end crimp on a ring terminal, and the other end a female insulated terminal. Fit the ring terminal to the "B" battery terminal, the other end to the right hand 30A terminal. (You will have already connected the solenoid coil connections.)
Now you have a fused output that can be used for an accessory, i.e. heated handlebar grips. Just plug into the spare terminal.
Note: this will be permanently "live" regardless of ignition key.
Hope this helps.
Ex Man of Kent now Kentish Man!
Hope this helps.
