- Mon Dec 11, 2017 5:24 pm
#7946
Periodically, the mikcarb on my 2004 350 bullet starts pouring fuel from the overflow. Not all the time, usually if it's been sat for a bit with the fuel off. If I give it a few sharp whacks on the float bowl with a bit of wood, it stops.
I've meticulously set the float height, the float is in good condition but I've even tried another one from a spare carb. I've replaced the needle valve and seat with a brand new one from our hosts and it still does it.
The intermittant fault and the fact that "percussive maintainance" sorts it says sticking needle valve to me. However it's brand new, the carb is meticulously clean (ultrasonic then solvent bath) and was fitted with an inline paper filter. I've inspected it several times and can see no sign of muck or damage.
I was wondering if anyone knows of a viton tipped needle valve that'll fit a mikcarb? I've had good success with these on japanese bikes. Maybe one of the mikuni ones?
