- Wed Apr 12, 2017 5:35 pm
#7246
My friend called round on his Meteor Minor today, fresh out of hibernation. Here it is with my Bighead Bullet, both 1959 although mines 1960 spec.
We went for a short spin today and swapped bikes, quite a contrast. The MM is really smooth and sophisticated by comparison. Even though they have the same frame they both have a very different feel. They are both very tractable and will pull from 30 in top, but the bullet has quite a bit more low to mid range grunt. The MM comes into its own at higher speeds and will keep on going when the Bullets running out of puff, but overall there's not much in it. It was good to compare two under rated classics.
