- Fri Nov 17, 2017 7:35 pm
#7886
I have a Continental GT efi. Shortly after purchasing it new last year it failed to start. All of the electrics worked ok, all of the fuses were intact, but the petrol pump failed to make the usual priming buzz. I checked the prop stand switch and the clutch lever switch, lubricating with a squit of WD40 and also gave the same treatment to the kill switch, all to no avail. The motor turned over on the starter and the dash display activated as normal. Being unable to trace any loose wires or connectors, I left it in disgust overnight. The following morning I gave it another try and everything worked normally, first go !.After that, I had no further trouble until today when the fault re-occured. I have carried out all checks as previously described with no response. Any ideas out there?. Has any Continental owner had a similar experience?
Any advice gratefully received.
