- Mon Oct 09, 2017 4:33 pm
#7766
Afternoon All
Phil here with a tatty troublesome 2000 350 Bullet that i suspect has been owned by several luddites over the years and has suffered in its 35,000 kms its reached to date
Long story short the bike has been been rewired at some point due to allegedly a short in the right hand switch gear and ignition switch ( it is hpi clear) which lead it to being hot wired over to get it running and then the next owner rewired it completely before selling it on with next to no miles under its belt between mot's to me so I which i suspect is because the head gasket was peeing oil everywhere but i digress
some of you may have seen the issue over on the midland bullet forums
Currently the bike is overcharging buy some considerable amount, when i first noticed it was putting ut 15.1v at idle rising to 15.6 when reved dropping to 14.9 and 14.7 with the dip beam lit
New combined reg/rec was ordered off ebay to replace the same and was duly fitted and showed the same results as above!
just to rule it out i bought a good second hand set of the original separate reg/rec boxes which when fitted reduce the voltage somewhat to 15.1 when revved and 14.9 at idle
with my limited electrical skills ive tested what earth cables i can see and all have made the beep sound on my multimeter i intend to borrow a second metre and double check all readings but my skills are very limited with electrical wizardry!
now the only thing i can think that i could of done wrong was when i when i was re routing my throttle cable back through the casket ( it had been left to dangle ) to go under the tank (before i found it overcharging) i must have touched something electrical in their with the end of the cable as there was a small spark from around the ammeter area
currently when ignition switched on with kicking over the bike to find TDC it reads positive with ignition on ( not running ) but reads negative when the bikes running but battery is obviously still overcharging
has anyone ever seen this before? i know the answer would probably be to throw a B/B power box at it but if 2 new reg recs and a good used set are still allowing it to over charge then it suggests that something else is wrong and a power box could just mask things
any help would be most appreciated on thing I could check ( with electrical limited knowledge )
Thanks in advance
Phil
Thanks in advance
Phil
