- Thu Sep 21, 2017 11:28 am
#7722
Hi. I've recently purchased a second-hand 500cc Electra X which I'm really enjoying, apart from the clutch that is.
It seems that whatever I do to the clutch adjustments – both cable and internal – the clutch is incredibly heavy. It's certainly rideable, but I'm going to end up with Pop Eye's left arm!
It's also reluctant to go into neutral when stationery (when running) as if the clutch isn't engaging properly, but the more I adjust it to alleviate this problem, the heavier it gets.
It's unlikely that the clutch itself is at fault as the bike's only done 1500 miles (and has been well looked after).
Has anyone else come across this problem on this particular model? (all I can find on the internet is similar problems on other models which have different clutches).
Thanks in advance for any help/advice!
