Hi all... once again thank you for all thoughts and suggestions on the cause of the broken piston. After reading about porosity and a close study of the piston I'm pretty sure porosity is not an issue in this case, but a weakness in the casting/material may somehow be the cause of faillure. Presto... the bike has high capacity oil pumps from our host, so there is plenty of oil around in the system. Maybe your reference to no evidence of oil on the outside can be explained in the fact, that I cleaned the engine outside with kerosine and viped the piston clean before taking the pictures. Or maybe you had something different in mind? Gwilly... I have taken a picture of the gudgeon pin (see below)... After all, maybe this little piston incident can not be explained in a rational way one can conclude on in such a way a "next incident" can be prevented. Hopefully I can rebuild the engine to a greater strength, that will suit my way of riding the bike... regards Jacob
