By NicoV
#7415
I recently bought a new UK-made silencer. There is a leak between the exhaust pipe and the silencer. Apparently the Indian-made exhaust pipe is a bit too "narrow". Even if I turn the clamp very tight, there still is some leakage. What would be the best way to fill this approx. 1mm of space between exhaust and silencer ? Some kind of cloth or filling ?
By Gwilly
#68282
You could make a wrap around sleeve from aluminium, something like a cut down drinks can.
cut to fit exactly around the pipe with no overlap or gap, then slide the silencer on and tighten clamp..
Wont rust either..
