- Sat May 20, 2017 9:34 am
#7339
That's my 2017 Bullet now run in, Only one small problem at 500 miles, it developed poor tick over and hesitation on opening the throttle, This was cured by my dealer putting in a lower grade spark plug, and this cured the problem, The thinking was that with the bike being run in at 1/4 throttle openings the engine was not running hot enough to clean spark plug tip so spark plug fouling up. However after some investigation and trials it was found to be the spark plug cap at fault, so with a new NGK cap fitted all is well on its 8 grade plug,(if you think RE India used cheap plug caps in the past well they seem to have found an even cheaper one to use?. the only other problem is the rear brake lever loose on its mounting causing a slight rattle at times. The Abs brakes are proving to be very good with braking around corners possible with no sign of wheel lock, so to an old school biker who learned to ride bikes with drum brakes (or should they be called no brakes?), this inspires confidence. Once the bike gets over 60 mph in 5 gear you feel you want another gear so an extra tooth on the front sprocket is in order and with a bolt on sprocket on the rear there is room to play with the rear size as well, So when we change the front sprocket the back brake lever will be sorted and all will be well. This bike was a replacement for my 2009 bullet Electra Efi and the 2017 bullet Efi is a major improvement on this machine in all areas, I assume that maybe Harris performance have been busy improving these machines, So to sum up I am very pleased with this machine well worth the £3999 price.
