- Thu May 04, 2017 7:01 pm
#7306
Hello all
Clutch cable snapped which is a bit odd bearing in mind only done 2200KM on Thunderbird 350 5Speed (Indian) reg: 2003 - Ordered universal kit and connected up to clutch lever all good BUT now realise that the Barrel the other end will not fit through the External Casing Cable Adjuster - I presume that I will have to unsolder barrel (if possible to do?) or cut barrel off and attach a solderless barrel, or am I missing a trick here? - Any advice greatly welcome - Thank you
