By Cafe Racer
#7244
As I have short fingers I have just replaced the clutch and brake levers on my 2011 Bullet Electra EFI with Hitchcocks adjustable levers. I expected it to be a complicated job but I am pleased to report that you can do them both in 10 minutes. The brake lever is easy, you just unscrew the lever bolt and swap levers. For the clutch I was advised to loosen off the cable adjuster to give some free play, but if you pull in the clutch you can then wedge the clutch open by putting an off-cut of wood between the clutch actuation lever, on top of the gearbox, and the frame. This gives enough slack to swap levers and you haven't altered the clutch setting.
By Gaz262
#67119
Cafe Racer: Sounds like a plan.... Do you have the item numbers for the levers you fitted please mate?
I reckon our Effie would like these maybe as an Easter present :)
As Leon said, it's not often people post here with tales of things going well - What a refreshing change.
Cheers
By Cafe Racer
#67129
As Adrian says part number 92574, but I was told they come in a longer size for later bikes, so make sure you tell Hitchcocks your model and year.
