- Wed Mar 29, 2017 11:23 am
#66704
Hello Dutto, Some Amal monoblocks (& concentrics I think) have a semi-circular groove with a fine drilling in it close to where it bolts on to flange. The idea is to give universal fitment of carb. to bikes that may instead of horizontal have inclined or even 'angled' fitment carbs. to prevent fuel leakage into engine as reported in the event of the fuel tap being left on & the float chamber float/pin sticking allowing excess fuel to enter. (some Mikarb/Mikuni carbs have a excess fuel drain tube which exits below the engine.) Question 1 Has the bike never idled properly, in which case perhaps the carb has been wrongly jetted or it needs cleaning. Question 2. If it was previously o.k. have you recently stripped/cleaned the carb in which case you may have inadvertently cleaned out any 'gumming up' of this drilling which a previous owner has compensated for by changing the jet. If so, then you may have answered the question & blocking the hole is the simple solution. Hope that helps.
