- Sun Mar 26, 2017 12:11 pm
#7189
Hi Guys. There’s a funny noise when starting to accelerate my 1996 535cc, just like piston slap. It is only there if I use more throttle than I need to hold the speed constant on the flat. And it doesn’t seem to matter if it is just a millimeter of throttle movement or WOT (wide open throttle). And it makes the same noise however much throttle I use and at any revs and whether engine is hot or cold - so long as there is a just a bit of acceleration. If I keep a constant throttle, the noise disappears until I next accelerate.
So I removed the head and the barrel and found the gudgeon pin is slightly loose in the piston, looser than when I installed it ~1000kms ago. I can see movement between the gudgeon pin and piston by the layer of oil squeezed out as I rock the piston (see comparison image below) and it feels like there’s ~1/4 millimeter slop (image in my photobucket account Chrisd200).
There is no discernible play in any of the other bearings though. This all happened after ~1000kms with a badly unbalanced engine, now fixed.
So, the question is this - is that wear critical? If the piston is worn where the gudgeon pin fits, perhaps caused by the shaking from the unbalanced engine, can it lead to catastrophic failure of the piston? (NB I have our hosts steel conrod and needle roller bigend and this is our hosts 535cc high comp piston).
Any comments? Yes, the best treatment would be to camera capture the noise and post that – but the bike’s in bits right now because of the noise.
Cheers, ChrisD
Cheers, ChrisD
