- Sun Mar 19, 2017 4:43 pm
#66576
Looks like the regulator /rectifier is faulty.. Volts from battery with engine off were 12.3. Started it, and revved engine and it took a few seconds to slowly climb to 14.2 volts. However, letting the engine back to idle it stayed at 14.3 and even switched off and on it stayed at 14.3. Turned lights on and dropped to 12.1 then when revved up went to 14.2 but dropped back on idle.
However, one corner of the battery has melted slightly and signs of acid spitting out. So, new rectifier needed and guess it'll be our hosts UK made one.
