- Mon Feb 20, 2017 2:16 pm
#65868
It has 4300 miles, and did have an aftermarket exhaust on it at one point for around 200 miles. I took it off and put a K&N air filter on it. The EFi has not been "adjusted" as far as I know and should have the original map on it. The shop it an authorized RE shop and he tested tps, o2 and 1 other sensor and all check out. He took a throttle body off a new bike, put it on mine and it worked fine. He could not explain why it made the difference, but it did. He rode it for 40 miles or so and I did another 60. It started acting up, so I put it up (he was swamped with work, and I was out of the country for a few months). Now here it is the spring and I'm looking to see if anyone else had the same problems. It gives up power around 30, no matter the gear, although you can fiddle with the throttle to keep it going to a good place to stop, but the popping gets more and more and gets pretty bad (blowing the filter door open). I don't have the original filter as it was misplaced in the more, but didn't think that the filter alone would cause that much of an issue.
