- Mon Jan 30, 2017 5:25 pm
#65490
On most bikes the correct way to adjust the chain is with the suspension compressed, but, most makers give a figure that is looser than required to allow you to adjust it more easily with the bike on the stand, compressing the suspension then tightens the chain.
Velocette chains should be adjusted with the rear shocks removed and a solid bar the correct length in their place,
I guess you removed the chain with the bike in the same condition as it is now so despite everyone's best guess only seeing the bike will determine where the problem lies.Good luck I am sure all will become clear very soon.
PS, I hope it's not possible you had another chain laid around which got mixed up, did you?.
