- Mon Aug 01, 2016 7:16 pm
#6539
So, i have a 1994 bullet with diesel engine.. double leading front brake, made the connector arm adaptation, This brake was Always a hassle to adjust(as with my jawa, also has a twin leading front brake, adjusting is 2 min. work and works good!)
I had the brake keys(those levers which push the shoes against the drum, what are they called in English?) machined down to 20,0mm so both were equal and more pressure against the drum, new linings, made to diameter of the drum, i thought after adjusting braking was reasonable and would improve, but it got worse over time, also more spongy..
Maybe the distance from the 2 axles to centre is not equal? Also it seems the brake plate is not in a right angle on the axle.. it tens to tilt a bit..
Anyway, a drum brake this size and this lining material should be able to work well..
is the 'improved'2002 brake plate & stuff better?
-yes i know how to adjust a double leading drum brake, but when tightening the lever makes the wheel turn more freely, something else goes wrong..
am thankfull for any tip!
