- Tue Jan 10, 2017 2:16 am
#65298
My Cortina let go on the motorway at 70 mph. The cabin filled with white/blue smoke that billowed everywhere. I drove it home like that. The #3 piston had a hole melted in it and molten metal had run down around the rings.
The SAE engine oil grades are measured at 100 C (originally was 212 F) as far as I know, due to the approximate cooling water temperature in a water-cooled engine, and, at the time these were established (in the 30s), was thought to be about the temperature that the oil ‘saw’. The SAE 40 grade spans about 13.0 to 16.5 cSt at 100 C and the SAE grade spans about 17.0 cSt to 21.5 cSt at 100C. This is the same for multigrade or monograde oils although the multigrade oils are often at the lower end of the range (easier to meet their multigrade requirements). If we take the midpoints there is about 6 cSt at 100C difference between the two. This is a reasonable amount at this temperature. If we take Presto’s point about differences in ambient temperature we can expect that with an air-cooled engine the differences in oil temperature could be significant (as long as there wasn’t extended periods of idling). A good quality 10W – 40 engine oil will have a viscosity of around 100 cSt at 40 C and 15 cSt at 100C, whilst a good quality 15W – 50 will have a viscosity of around 135 cSt at 40 C and 20 cSt at 100 C. These oils have a viscosity index (VI – an arbitrary index of the oil’s viscosity variation with temperature) of about 150 so if we were to graph them we would have parallel lines (need to use log paper because it is not linear). We would see that the 6 cSt at 100C becomes larger as the temperature reduces.
With the unit construction engine the engine oil also lubricates the gearbox. Multigrade oils generally use an additive, called viscosity index improver that is added to the base oil to improve the VI and make it a multigrade. This additive is a large polymer that expands when hot and curls up when cold. The shearing effect of gears can ‘chop up’ the VI improver and reduce the overall viscosity over time. The lower viscosity grades of oil now on the market e.g. 0W - 30 and so on, are specified by manufacturers for fuel efficiency. This is fine as long as the surface machining is really good and the tolerances excellent.
From my experience an oil viscosity of around 15cSt at 100 C is fine for a piston and liner so Rattlebattle’s selection of a 10W – 40 would be OK. I think at worst there could be some more oil consumed (gets past the rings and burns) or maybe leaks out some seals. It will certainly get pumped around the oil circuit more quickly when cold.
I have been using Penrite MC4-ST 15W – 50 in my B5 and it seems OK. This choice was more about availability than anything else.
I agree with Leon that it may be out of place with the initial topic but the discussion developed into one of engine temperature. Hope we haven’t caused any meltdowns.
