- Fri Dec 23, 2016 2:16 pm
#6965
Having a bit of a senior moment with the clutch (Iron barrel, 4 speed type), it's a couple of years since I did one. Having dismantled it, put in new bearings (54) in the sprocket, new plates, new pad (improved spinning type with bearings), new outer plate, new circlip and single long rod and new springs. I have assembled it the way it came apart, but when I tighten up the three bolts the springs are fully compressed and the clutch and lever are solid. If I slacken the three bolts off so they aren't fully compressing the springs then the clutch works fine. I've been around the block and through traffic and it works ok, but those three bolts aren't tight, but they should be. What could I have done wrong, if I leave then untightened then they will work their way out. There's also a noticable whine, any suggestions?
