- Sat Nov 19, 2016 2:58 pm
#6885
I recently took my '94 Bullet 350 for it's first run and noticed that it was very difficult to select gear when stopped. If I stop in first I have to kick the lever hard to get neutral and it is almost impossible to get to neutral from second. I am still getting used to the neutral finder as I am more familiar with BSA's and Triumph boxes. The bike was laid up for about 20 years before I bought it. When I checked the gearbox I found grease which the handbook said is standard but I topped it up with 85/90 gear oil not the 20/50 oil recommended. I adjusted the clutch as recommended without much success. Looking for information on adjustments I found a reference to the detent plunger being a possibility for my problem. Where exactly is this plunger, what does it do and is it necessary to strip the box to access it?. Although I was trained as a mechanic is a previous existance many moons ago gearboxes still frighten me..!
