- Thu Nov 10, 2016 6:24 pm
#63911
The clutch-switch is only in Play when the bike is in gear. Select neutral.
I would not be overly worried about possible damage to the sprag due to stall potential; how often do you stall your bike on a hill and actually have the bike attempt to roll backwards?
Back-firing on start-up kills the sprag (and the oil-pump worm) followed by shut-down compression bounce-back on the piston/crank.
By engaging the decomp: Initial voltage drop and current draw on the battery is able to stabilise, (improved spark) the crank gets up to full speed, (more inertia) and the cylinder is 'primed' with fuel.
