- Wed Oct 26, 2016 3:38 pm
#63538
OK guys, a magnet when heated has it's magnetic strength reduced, and recovers when it cools, while riding the bike the airflow helps the cooling, and an immediate restart can be quite easy however when stopped the engine heat rapidly conducts along the armature on the SR series mag's and heats the magnets giving a weak spark. It took me four years to find the cause first time, since then I go straight to the cure. ðŸ˜ðŸ˜ðŸ˜. Your choice whether you believe me or not but I am sure that is the problem as I have cured three bikes with this.
