By pd110961
#6721
just fitted my new Hitchcocks panniers, and think personally that they look great!
By neddy
#62893
Very nice, fits to the bike great, really is a "looker"
By Jaffa
#62897
Hi they look really good any pic what they look like at the rear and where the easy to fit I like the look of them nice job
By Rattlebattle
#62906
I've been thinking of buying those for a while. How easily do you think they'll be to remove? Did you wire in the rear lights? It would be great if you'd give us all your thoughts on them. They do look great though, and wider than I thought. Very nice.
By pd110961
#62908
they took about an hour to fit. The mounting frame bolts in three places. one on the top shock mount, and the other 2 on the mudguard support 'D' shaped thingy suing substantial wrap rounf brackets.
the one that fits on the bottom run was easy, but the top one needs either the mudguard taking off or a strong lever or screwdriver to make room to get the bracket round.
the panniers themselves fit to the frame with 4 off M4 bolts and nylock nuts, through rubber grommets and steel spacer so there is no direct stress on the fibreglass.
I have not wired up the lights yet, but will do.
Will post a photo from behind, but they are just narrower than the handlebar ends
