- Fri Aug 12, 2016 1:12 pm
#61120
Leaving it idling for 10 minutes or more will start to cook the engine, it is air cooled and needs air flow to cool it. The engine does have a temperature sensor but you can point an IR thermometer at it.
I'm running mine on Mobil 1 which is full-synth bike oil but a very good oil that I trust, I've had truly humongous mileages out of vehicles running on it (do check the JASO/API that the oil is for wet clutches). Synth and semi-synth are just more refined versions of ordinary mineral oil, so use the best, whatever.
If the O2 sensor has been removed then check you have a bypass resistor in its connector. This is done to fool the ECU, often with a silencer swap. Do all indian domestic models have the O2 sensor?
The motor is push rod, "tappet" noise is normal. The EFI has hydraulic lifters, no adjustment there but the cams can be adjusted for backlash - if they're not bust don't fix them. The tappets as such are under that little cover on the block, what we hear are the rockers clattering in the head.
