- Thu Aug 11, 2016 10:29 am
#6572
Hi,
I've just bought a 2004 bullet 500es.
I own a good set of spanners, ratchets, screw drivers, allen keys, and your general assortment of pliers.
I also have a soldering station, wire strippers, cutters and crimping tools.
And I recently purchased a set of both inside and outside cerclip pliers.
So outside of the Enfield specific tools mentioned in the workshop manual, what else would I need? I'm going to put the Bob Newby clutch & beltdrive, electronic ignition system with powerbox, pvl coil, audicator, rocker relief and 5 speed clutch arm improvement. I won't be yet working on the engine itself (valves, rockers, piston, bottom end, ...), outside of any maintenance it requires, but am planning to do so in the future.
I figured a set of pulley/bearing pullers would be nice, but I can't figure out which I actually need out of these sets:
Any other tools you would recommend I'd get?
- https://www.hbm-machines.com/producten/ ... trekkerset
- https://www.hbm-machines.com/producten/ ... 150-200-mm
- https://www.hbm-machines.com/producten/ ... et-8-58-mm
