By Revband
#60468
Here we go again, hold tight guys it could get bumpy.
By Reg
#60473
Oh, am I thankful for a simple iron barrel bullet.
By Dennis C
#60476
The trouble is that a simple fault somehow manages to get a reply which is far from simple, helpful?, no I think not. My final say.do your worst J.
By sofiaspin
#60477
What an extraordinary post! Leon Novello gets it wrong for the first time since 1949!!
By ric
#60480
Temporary MIL lamp illumination and juddering without any codes being logged = low battery charge.
- just in case you don't get a fault code.
As for the alleged EFI unreliability... I've just returned home this evening from a combined Land's End to John O'Groats and North coast 500 run the majority of the 2,421 miles of which were travelled were in pouring rain. No Mil codes and no problems whatsoever, nor did the EFI get blown off it's manifold or the electronic ignition fail and all with an average fuel consumption of just under 99 MPG. An absolutely enjoyable and comfortable experience on a bog standard B5 EFI (apart from rack and top box)
The only maintenance was to put a little air in the tyres to compensate for the wide variance in ambient temperature between South and North and to adjust the chain by 1 notch on the snail cams. No determinable amount of oil was consumed either nor anything found dripping from or obstructing the breather pipe :)
By sofiaspin
#60481
Great post ric and inspiring too, I have done brute mull Iona and the borders this year but not the 500 or end to end, can you post any bike pics?
By Leon Novello
#60483
Sofiaspin: If anyone wants to know, I`ll be standing in the corner all afternoon till class ends.
By Presto
#60485
The alternative views between myself and jefrs here is a misunderstanding - on my part I guess. I'm referring to the ‘check engine’ light which can be connected up at any time and will flash in a sequence of long and short pulses: e.g. six short and six long. This sequence identifies the faulty component or cause of engine malfunction.
trust this won't spoil anyone's day. ;-)
By ric
#60498
Sophiaspin - Here's one which should hopefully give access to all the others once they go in the album - just the first, last and the Applecross pass are in there at the moment
