- Fri Jul 15, 2016 4:24 pm
#60251
PeteF, actually easing it over TDC is a sensible precaution, it is after all what you would do with a kick start, especially with no decompressor. In fact if you have a kick start, to use that and then hit the button.
Try kicking a goldie, it's street performance art, you always get an audience. For theft prevention they're left in gear on full advance and with the air slide closed to stop stuff going down the bell mouth, woe betide the foolish. The ElectraX should not need the arcane ritual of tickling, rolling the bike about to find neutral, priming, calling St Johns Ambulance, freeing the clutch and waggling levers, easing it over and praying. It's just too much effort and it looks like you're throwing toys out of the pram - the starter should be able to do the job. Check the battery condition
