By Cleggy
#6445
Dear Chaps, does anyone live near-ish to Marlow in Bucks, and also has two 389 Monobloc float bowl gaskets & two of the main jet block fibre washers? I'm stuck til Tuesday otherwise. I'd come get them & pay. My new purchase is leaking fuel from the aforementioned parts after cleaning the carbs. Thought I might get away with the old ones. TTFN Jack
By Cleggy
#60042
A pal o'mine turned up two 376 float bowl gaskets & jet block washers. But when fitted, the float bowls leaked like a sieve. So in desperation I fitted both new gaskets to one bowl & it sealed OK. So still short of float bowl gaskets. Any comments about why this should be? I took off the high spots on the bowl cover screw holes.
By Cleggy
#60044
No, floats & needles are OK, it is just the sealing of the float bowl gaskets. One gasket leaks, two gaskets seal.
By Cleggy
#60047
Not an Enfield I'm afraid Mark. 1964 model N15CS. Very much in the style of the Westwood Inters, but with a gearbox which doesn't bite back.
By Dennis C
#60048
The gaskets are soft, people over tighten the screws, they start leaking so the screws are tightened again, the mazak end plate is now distorted, the answer is a new plate a skim in a lathe or a temporary fix two gaskets, unfortunately petrol eats gasket goo in most forms, it turns to jelly and blocks the jets.
By Cleggy
#60052
Looking like a temp fix for both carbs with two gaskets for now. Be Tuesday now though.
#60063
Second Dennis on this, cover will be warped. New ones aren't that expensive.
