By Tim NZ
#59899
Pics of your EI box will assist in IDing what you have and how it should be wired...
Alternately you can contact me OFF list and I send you a few files with the wiring details and viable options...?
royalenfield AT clear DOT net DOT nz
By vince
#59864
Hi, different bike but possibly connected, I had a misfire that proved to be the coil on its way out. The bike would run ok at 50 for 20miles then it would spit if the throttle was opened, it would then only run below 40 then 30 then cut out. It finally was resolved as a charging fault burning out the coil. It was red hot to touch.! Vince
By RocketRR
#59932
Are there issues with the green ignition box as I saw it mentioned? My bike has the green box and a problem cleared after cleaning the box connection cheers
