- Tue Jul 12, 2016 11:16 am
#59910
PeteF, you're probably right but there is a tendency to apply too much and as Haggis found, it gets flung off rearwards.
I was given a can of Rock Oil by the dealer's mechanic. It's been used two or three times over the winter. I'm beginning to notice a regular vibration, "thrum, thrum, thrum" from the chain indicating it's ready for another squirt.
Adjusting the chain - I aligned the wheels and found the notches on the adjusters are not symmetrical, don't rely on counting notches. Adjust the chain and then pull the other side into correct wheel alignment. The autopunch makes a decent mark on the cams for next time.
The yuck comes off with a bucket of suds and Rim Wax cleans the silencer and wheel nicely. 'Tar and Bug Remover' takes the black blobs straight off but tends to leave sticky white over-spray spots of its own behind.
How do you clean a filthy chain, without removing the grease that is packed into it?
