- Mon Jun 27, 2016 2:05 pm
#59607
Nicely put Frank. as it says on the tech note on this site [Wet Sumping] 2. don’t overfill the oil tank – the lubrication system ‘breathes’ more easily if the oil level is not too high. Good advice is to refill with about 2 litres of oil at an oil change (rather than 2.25 litres some recommend). Checking the oil level by placing the oil filler cap on the filler neck (not screwed down) and keep the oil level midway on the dipstick. (For your peace of mind, even with oil below the low mark there may still be enough oil in the system. That is not, however, a reason to allow the oil level to drop so low!)
