- Sun Jun 19, 2016 9:18 pm
#59215
My take on it is this: the RE is essentially the same as the many 50s pre-unit singles I have owned that all ran quite happily with an Amal carb. For sure there are better carbs but how sophisticated does the carb on an ohv long stroke single need to be? Without emissions regs I very much doubt that RE would have resorted to fuel injection. But we are where we are. I believe the real culprit for poor running is crap fuel. Whilst I take Jefrs point re spark plug heat values ( and I too once holed a piston racing my 250 Suzuki Hustler against a Triumph Spitfire because I forgot that I was using the "town use" plugs) the fact is that back in the day most of us with road bikes stuck with the specified plug grade and adjusted the fuel mixture based on plug chops against the colour charts in n manuals etc. It seems you can't do this nowadays. As for messing around with the EFI I'm quite happy to do this on a bike for which there is a big user base and loads of knowledge and downloadable maps for different exhausts etc eg BMWs, using the GS-911; Triumphs using TuneEcu. I've not yet seen a definitive answer of exactly how the RE EFI works. Whilst I respect those who are sufficiently interested and skilled in cracking this, for my part I'd rather just bung a carb onto this low-revving anachronistic single and get it running as well as it can and I can. To have to pay for at least a PCV to get a STANDARD spec bike to run properly in my book is not acceptable, given the cost. Fair enough I suppose if you want to swap exhausts etc but even then it's still cheaper to put a carb on it. That is what I nearly achieved today; I ran out of time because I went for a ride on it first. Perversely it started first kick.......
