- Fri Jun 17, 2016 9:16 pm
#59179
Keeping things simple:
The BPR6EIX will be too 'cold' for the motor while running in. As such it will show a 'rich' (cold actually) indication. A '7' or an '8' may have been better for low speed running-in?
IF the plug does start to misfire, (?was it?) you have nothing to worry about giving the Bike a 'Handful' for a 5-10 second blast in a lower gear to clean off any loose carbon matter on the plugs insulation.
Presuming sensible running-in with the occasional tweek on the throttle in low load situations your piston and rings will be pretty much run in by now and will stand being given the occasional 3/4 - full 10 - 15 second runs, again; in a low load situation.
As for the Idle speed adjustment; technically it is not an Idle Adjustment, but rather it is an air-bypass bleed; it offset the effects of the 'Idle' fuel injection settings...
